December 12, 2006, 11:04 |
Solid mesh for heat conduction
Hi folks:
I am modeling a pipe flow where the pipe thickness is considerable (i dont wanna use thin wall option in fluent). So my question is how many nodes do I have to place inside the solid wall for heat conduction. Lets say my pipe diamater is 100 mm, and wall thickess is 10 mm. So I can use my pipe mesh size 5-7, in that case I will have only 1 node inside the wall. Any idea or comments. Thank you for you time. Munni |
December 12, 2006, 13:24 |
Re: Solid mesh for heat conduction
I want to plot gragh for some thermal parameters(for example temprature) vs time in unsteady condition of heat transfer in a solid body. Can you help me in this topic. thanke you very much.
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
