Single reference frame model
Old   December 10, 2006, 08:34
Default Single reference frame model
srinivas
somebody can help me how to use single reference model. my system contains two cylinders first one is rotating inner cylinder other one is stationary outer cylinder. the annular region between two cylinders is filled with the water.when i was used single reference frame model in my system.but the outer cylinder rorates instead of inner cylinder rotation, the flow profiles obtained in the oppsite direction. i applied these bounday conditions: 1) For fluid region:
Rotation speed : 100 rpm
Rotation of origin: (0, 0, 0)
Rotation of direction : (0, 0, 1) 2) For rotating inner cylinder:
Rotation speed : 0 rpm
Rotation of origin: (0, 0, 0.005)
Rotation of direction : (0, 0, 1) 3) For stationary outer cylinder:
Stationary wall
no slip condtion Please give information abt this problem
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 04:43
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Single rotating reference frame jing Siemens 1 August 29, 2003 13:44
