Gambit face link mesh, please help
Old   December 7, 2006, 10:58
Default Gambit face link mesh, please help
David
I am trying to link mesh two faces within a channel. The vertical edges of the two faces have concentrated nodes towards the edge and the horizontal edges have equally spaced nodes. when i link the meshes, the vertical and horizontal node spacings switch on one of the faces. Can anybody explain why this is happening.
Thanks in advance
Old   December 7, 2006, 10:59
Default Re: Gambit face link mesh, please help
David
Sorry i forgot to mention, i am linking the faces for periodic boundary conditions and have unchecked the reverse orientation option
Old   December 7, 2006, 13:44
Jason
The direction of the orientation may be wrong when linking your face. You should watch the arrows when you're selecting the faces to determine if you need to use the reverse orientation or not. Or, just try it with the reverse orientation option checked and see if that's better.
Hope this helps, Jason
Old   December 8, 2006, 08:27
David
Thanks for your advice, the arrows are all orientated correctly, i have gona ahead and used reverse orientation as its the only way i can get the periodic boundaries to work
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 02:10
mesh missing after export in gambit morteza08 Main CFD Forum 0 July 23, 2010 03:19
Face mesh and scheme Jonny6001 ANSYS Meshing & Geometry 3 June 21, 2010 03:57
Face link mesh Frederick FLUENT 1 March 14, 2007 12:15
