time step for unsteady turbulent flow
Old   December 7, 2006, 05:22
Default time step for unsteady turbulent flow
vishnu
how to deceide the time step for unsteady turbulent flows. is there any theoritical procedure avialable to calculate the time step.
plz help me
Old   December 7, 2006, 05:29
Default Re: time step for unsteady turbulent flow
bli
maybe evaluate the time needed for the flow going through the domain and then choose a resolution? but with chemical kinetics or other phenomena (combustion/explosion....)you may think the time scale for that specific phenomenon.
Old   December 7, 2006, 05:37
wabik
There is also an adaptive time approach to the problem. Instead of fix time step you can use adaptive one ...
PW
Old   December 7, 2006, 05:50
Emmanuel
If your flow is periodic, obtain the period ie. 1/frequency, then divide by the number of time steps you want say 100. This will be the value of your "Time Step Size".
Example your frequency is 220hz, then you period = 0.00454545s, for 100 time steps, your "Time Step Size" = 4.54545e-5.
The value you use for "Number of Time Steps" depends on the number of cycles you want. if you want 5 cycles then you use 5*100=500.
You can then use the default value for the rest.
Old   December 11, 2006, 04:25
vishnu
thank you....... is time step depends on the property which we require( for example temerature in turbulent flow or pressure in turbulent flow)?. does it depend on the accuracy of the property which we require?
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Time step, Number of time step, Maxximum Iterations per time step sandisk FLUENT 0 July 18, 2011 03:57
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 11:23
