Open boundary condition
Old   December 5, 2006, 20:12
Default Open boundary condition
suvash
Hi, I am using fluent and now facing some problem with boundary conditions! My geometry is a triangular cavity. I would like to give one side hot and other two open boundary so that I can see the boundary layer and that boundary layer is not affected by any other flow.
Could you please help me how can I use open boundary condition.
Regards Suvash
Old   December 6, 2006, 13:39
Default Re: Open boundary condition
Ralf Schmidt
i didn't understood your problem right. I think, you may use pressure outlet BC at the two faces that are "open".
Ralf
Old   December 6, 2006, 15:11
Phil
You might also try to use the far field pressure condition if you boundaries are sufficiently far away in comparison to your flow features. Phil
Old   December 6, 2006, 21:20
suvash
Thanks Ralf, I got the following in the fluent documents. Since I am simulating the natural convection then how do I do the pressure. Should I use zero pressure or operating pressure (101325 pascal which is default). Please help me.
"Pressure inlet boundary conditions are used to define the fluid pressure at flow inlets, along with all other scalar properties of the flow. They are suitable for both incompressible and compressible flow calculations. Pressure inlet boundary conditions can be used when the inlet pressure is known but the flow rate and/or velocity is not known. This situation may arise in many practical situations, including buoyancy-driven flows. Pressure inlet boundary conditions can also be used to define a "free'' boundary in an external or unconfined flow."
Old   December 7, 2006, 03:41
Ralf Schmidt
Hi!
you should NOT use the operating pressure for pressure out/inlet! For your case, with no resistance for the fluid to flow out (like you have e.g. in a pipe-system) then there is zero pressure at the pressure out/inlet.
The pressure far field BC is only working with some special settings - I don't have good experience with it concerning convergence.
Ralf
Old   December 7, 2006, 04:10
suvash
Thanks a lot Ralf, I have some more questions!!! Suppose it is a square cavity. I want to set up the left wall HOT and inside cold. Bottom, top and right surfaces are open. Is it ok if I set up bottom -> pressure inlet, top-> pressure outlet and right -> pressure inlet? What will be the temperature of backflow. I want to set up it as the initial interior temperature (cold). Is the direction of the flow normal to the surface? If I incline the cavity on right side, will the setup be the same?
Sorry to ask you so many questions!! If possible response me..
many many thanks.. regards Suvash
Old   December 7, 2006, 07:53
Ralf Schmidt
Hi Suvash,
the difference between pressure inlet and outlet is not very large, actually, I don't know it.
The backflow temperatur is the temperatur of the fluid, that flows from outside of your domain through the face that is difined as pressure out/inlet. That might happend, when an eddy developes close to the boundary that "sucks" fluid from outside inside.
The direction of velocitys from massflow inlet or vel.inlet can be set. They are ether normal to bondary or you can set the components of the vel (x,y,z)
Hope, it helps
Ralf
Old   December 8, 2006, 06:24
suvash
Thank you very much. It will definitely help me. Suvash
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 13:26
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 03:36
Slip boundary condition what is inside normunds OpenFOAM Running, Solving & CFD 2 June 4, 2007 07:45
