November 30, 2006, 03:27 |
iteration window
hello frenz While i give instruction to iterate after setting the problemonly the iteration widows opens up showing the co-ordinate axes which enteds as the no.of iterations increase without showing the residual,x velocity,y velocity lines.. Frenz plz help me sort out this problem. thanks
November 30, 2006, 13:48 |
Re: iteration window
Look at the main Fluent window and see what the output is. Do you see the residuals converging in your output? Also, check your residual monitors setting and see if there is something worng there (Normalize /Scale ) Good luck phil
December 1, 2006, 04:03 |
yes residuals r converging in my output at the main Fluent window.And also residual monietors setting too is o.k with scale. I guess this is the problem of graphics as the main fluent window also shows the error message of graphics when animation files r tried to save. thanks
regarding the iteration window | lnravishankar | FLUENT | 1 | May 18, 2011 06:01 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
Parallel runs slower with MTU=9000 than MTU=1500 | Javier Larrondo | FLUENT | 0 | October 28, 2007 23:30 |
Heat exchanger problem | chiseung | FLUENT | 16 | October 20, 2001 05:36 |
LES iteration window | Chetan Kadakia | FLUENT | 1 | August 28, 2000 09:32 |
