2D analysis and moment calculation
Old   November 27, 2006, 05:57
Default 2D analysis and moment calculation
carno
Hi All,
I have done a 2D dynamic mesh transient analysis. It contains a 1cm thick rotor, for which I want to calculate power. What the thickness of the rotor fluent takes to calculate moment in "report" function? If it is unit meter, shall I multiply moment value by 0.01 to get moment for my case?
- carno
Old   November 27, 2006, 10:10
Default Re: 2D analysis and moment calculation
Jason
You should set the depth in Report->Reference values
Good luck, Jason
Old   November 28, 2006, 02:08
carno
thanks Jason
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 15:07
Blank white space in flow analysis? Welshnathan Phoenics 1 March 17, 2011 14:10
multifield problems on ia64 zegtuhetmaar ANSYS 7 October 21, 2010 14:18
analysis 3D fan v_h_memar FLOW-3D 4 February 5, 2010 21:26
Parm.inc error when running analysis Chris Wood Siemens 3 November 1, 2004 13:28
