porous media with variable porosity
Old   November 25, 2006, 18:53
Default porous media with variable porosity
Kevin A.
Hi all, hope someone can guide me. I am trying to implement a porous media model with random porosity using the Eulerian model, so far I have implemented the initial porosity distribution modifying an example UDS. My problem is, what do I have to do to keep the porosity fixed during transient calculations? by using a UDS so the porosity distribution is read at every step?(that seems to me quite inefficient to say the least)
Please guide Thanks in advance Kev
Old   December 7, 2006, 23:43
Default Re: porous media with variable porosity
Sidy
Hello Kevin, I am working on a problem I think is similar to yours, I have a 2D cylinder with a moving top wall (only moving down) and a solid stationary bottom wall, the 2 walls on the sides are pressure outlet boundary conditions. in the interior of the cylinder, I want to have a porous media (can I also add fluid in the porous media). As the cylinder comes down, the porosity should should decrease (does fluent do this automatically internally or do I have to define a UDF), as a result fluid comes out through the presure outlet boundary conditions. I have been reading fluent tutorials and so on. Can this be done and can someone help me with this.
Thank you
Old   December 8, 2006, 04:53
Ralf Schmidt
Hi Kevin,
I was trying to set a porosity distribution with the example udf also! But somehow, i didn't succseed.
Could you please send me the udf you are using?? To: RSchmidt@iwt-bremen.de
Thanks a lot
Ralf
Old   December 24, 2006, 11:56
zeboudj
Dear, I want to work on project using fluent but no idea about the capability of such soft for porous media modeling.
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
