November 23, 2006, 02:05 |
Gambit not openin file........
hello frends i m in a big trouble as i m unable to open any file n the displayed message in the command prompt is Unable to open the dispaly.....as it cannot open connect stream....plz help me out plz.... thanks
November 23, 2006, 02:10 |
Re: Gambit not openin file........
Hi, Some time ago a had problems opening files with Gambit, what I did was to put the file in a directory without blank spaces in their names. For example Gambit didnīt open files in C:\Documents and Settings but did open files in, for example C:\cfdcases
Hope this helps! |
November 23, 2006, 02:48 |
looks like you are using Gambit under Windows in Combination with Exeed. Perhaps Gambit can not connect to the x-server Exeed. As a workaround try to find the directory of Exeed in the Programfiles and find exeed.exe and start it before starting Gambit. But to make things right, try to install exeed that way that everybody can access it, and it should work. Regards, Alexander |
November 23, 2006, 06:02 |
thanks Alexander.....
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 | electrosin | OpenFOAM Installation | 40 | May 31, 2016 06:11 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 14:43 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 05:26 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 05:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 07:43 |
