Vertices from Volumes
Old   November 12, 2006, 20:53
Default Vertices from Volumes
Vikrantca
Hello, Iam generating a GAMBIT journal file from c++ code. My application requires creation of several hundred equi-spaced volumes (I use bricks in GAMBIT). After creation , I need to create a face out of the space between two bricks (there will be 4 faces that can created). My questions - (a) is there a way to access the vertices of a volume that is already created or (b) is there a way to access the edges or faces of a volume already created. I want to do this thru code.
thank you in advance. Best Regards, vikrantca
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 03:39
[GAMBIT] Connecting volumes makaero ANSYS Meshing & Geometry 4 April 15, 2010 20:18
correcting double vertices Tom Siemens 3 October 3, 2006 20:18
union of volumes CHUBBY FLUENT 2 May 4, 2001 07:31
