November 10, 2006, 11:26 |
Problem starting Gambit
I have a problem in loading Gambit, which gives a constant error as quoted below...
_____QUOTE START_____ c:\temp>gambit Current gambit usage: 1. sengvm@REU111945300 Fri Nov 10 15:49 REU111945300 License for gambit expires 16-aug-2007. Using X_DEVICE_DRIVER with standard visual. gambit XIO: fatal IO error 0 (No error) on X server "REU111945300:0.0" after 1466 requests (1463 known processed) with 209 events remaining. _____QUOTE END_____ Following is the configuration for reference... __________ Hardware... Motherboard chipset : Intel DQ965GF Processor : Intel Core 2 Duo 6300 1.86 GHz Memory : 4 GB DDR2 @ 667 MHz Graphics : nVidia GeForce 7600GT / 256MB VRAM / PCI-E x16 Display : Iiyama ProLite E1900WS-S1 @ 1440x900 / 75 Hz __________ Software... Operating System : Microsoft Windows XP Professional (2002) SP2 Exceed for Windows NT : X Windows Server Version 5.1.3.0 (up to 64 connections) (installed locally) Gambit : 2.0.4 (I think) (installed on a network drive - does not load, gives the error quoted above!!!) Fluent : 6.0.12 (installed on a network drive - running fine) __________ I am not sure what more information is required to solve this issue. In a previous post, a similar problem was identified. The proposed solution was to delete any '.lok' file on the system. I could not find any '.lok' file on any local or network drive. There's a lot of work that I have oustanding because Gambit won't start. Please help! Any suggestions? Anyone? Thanks and Regards, ViHAR MALViYA |
Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7 | pdilly | FLUENT | 23 | April 2, 2016 13:10 |
Gambit geometry problem | cestrin | FLUENT | 3 | July 4, 2012 03:33 |
Gambit Problem Size Function | El Wastl | ANSYS Meshing & Geometry | 12 | April 15, 2011 08:17 |
Problem importing iges file to Gambit | Tassos | FLUENT | 0 | May 7, 2008 05:28 |
Startup Problem in Gambit 2.2 with WindowXP | Win Win Maw | FLUENT | 3 | January 25, 2006 12:09 |
