How to animate with Fluent?
Old   November 9, 2006, 12:41
Default How to animate with Fluent?
Pawel
Hello i'm trying to create animation of the solution i fluent. I've saved all frames in hmf's, and now i'm not able to create mpeg file (CX_Hardcopy_Window: error opening PPM file e:\data\mov\2\velocity_2_0891.ppm). Is there any solution to that? Is it possible to construct a scene which consists of residuals figure, and contours?
best regards.
Old   November 15, 2006, 03:43
Default Re: How to animate with Fluent?
wabik
If you have ppm files saved you can just open vis GIMP ... open one ppm file and next ones as additional layers and save as animation gif ...
Brgds, PW
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 05:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 03:44
animate on plane hakkż FLUENT 2 August 25, 2003 14:58
