Gas flow profiles in mixing tank
Old   November 8, 2006, 05:52
Default Gas flow profiles in mixing tank
srinivas
My system is gas sparging in solid liquid system. The system consists of one inner cylinder which is a solid and a outer cylinder is filled with water up to a certain height. The inner cylinder also acts as a gas induced impeller. Here gas is evolved at the inner cylinder surface.
The gas profiles evolved are attached to the inner cylinders surface. where as the experimental profiles shows that the profile is away from the inner cylinders surface.
I tried with different turbulence models but there is no change in the gas profiles.
Kindly, give me the solution to this problem.
3D mixing tank using MRF/SRF cfd_confuse Main CFD Forum 1 September 13, 2016 03:43
Free surface flow settubg boundary conditions and plotting velocity profiles prashanthreddyh FLUENT 2 October 21, 2015 10:58
negative pressure in mixing tank vidhya CFX 1 April 26, 2011 23:16
3D mixing tank using MRF/SRF cfd_confuse FLUENT 0 October 2, 2010 04:46
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 13:34
