Problems with Dynamic Mesh: DEFINE_GRID_MOTION
Old   November 2, 2006, 08:31
Default Problems with Dynamic Mesh: DEFINE_GRID_MOTION
Claudia
Hi everybody,
I'm trying to work with dynamic meshes with a DEFINE_GRID_MOTION UDF. The UDF does work, so the boundary for which it is defined does move, but the fluid-mesh stays the same so that I get after some iterations problems with negative cells. So does someone know this kind of problem and can tell me what I forgot to enable so that the interior-nodes will also change their places so that I will not get negative cells
Thanks
Old   November 2, 2006, 11:04
Default Re: Problems with Dynamic Mesh: DEFINE_GRID_MOTION
qincz
maybe your time step is too large. in one step the boundary moved so big distance that u got the negative cells
Old   November 3, 2006, 02:45
Claudia
I don't think that is the problem, because I can run 6 timesteps till the distance the boundary moves is so big that I get negative Volume cells. The problem is the surrounding cells do not react on the slowly motion of the boundary....
Old   November 3, 2006, 03:57
cfdxue
1) pay attention to collaps factor,... ur mesh is not going to collaps,.. chang it,..
2) decrease ur time step,.. it could work, if ur collapse factor is little bit wrong,...
if its not work,.. inform me ur grid size,.. and time step,..
Old   November 3, 2006, 05:02
Claudia
20 minutes ago I got it. Now it works. The mistake was the I took no trinangular cells. I took rectangular cells. But its for me a little bit strange that it doesn't work because of rectangular cells.... does somebody know how I can get it work with rectangular cells?
Thanks for the response. What is a collapse factor and where can I check and change it? Maybe this problem will appear someday and it would be good to know the answer...
Thanks a lot!
Old   November 3, 2006, 05:47
cfdxue
It should work with both mesh,..
if u like, u could send me case file and udf at cfdxue@yahoo.com,..
best luck
Old   November 3, 2006, 12:59
Eirik
Deformation of hex-meshes is initially swithced off in Fluent. You can turn this feature on through the TUI command 'def mod dmc sp soas', alternative set the scheme variable dynamesh/spring/all-element-type? to #t
Regards,
Eirik
Old   November 3, 2006, 14:22
Claudia
That would explain why it doesn't work with rectangular mesh. Unfortunatly I don't know how to use both of them... can you tell me how and where I have to make the changes, please?
Thanks a lot!
Old   November 3, 2006, 15:25
Eirik
In Fluent's Text User Interface (TUI - perhaps main window is a better phrase), just type the command I gave you. Typing return after each word will bring you to the next menu-level, like it's written brings you all the way down in one step. You'll then be prompted whether or not to turn the feature on, just answer yes.
- Eirik
Old   November 3, 2006, 16:34
Claudia
Tanks a lot! I will try it on Monday morning first! (Here it is 22:40 at the moment Friday evening....) have a nice weekend!
Old   November 6, 2006, 03:28
  #11
C. H.
Thanks a lot!
It does work!
Claudia
Old   September 25, 2013, 15:23
Alexandre Felipe Medina Correa
LexMedina is on a distinguished road
Dear Eirik,
I am having the same problem as Claudia. I tried to set the command you gave on TUI, but it didn't recognize the comand dmc...
I tried part by part, first with def, then mod, works fine. But the 'dmc so soas' does not work that well. Could it be a version problem? I am using 14.5 here in university.
Thanks,
Alex
LexMedina is offline   Reply With Quote
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 2 May 7, 2020 11:42
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen su_junwei OpenFOAM Meshing & Mesh Conversion 2 July 27, 2008 00:58
Can Fidap solve dynamic mesh problems? Sandy FLUENT 0 September 29, 2003 01:45
