multiple body problems (really trivial)
Old   October 23, 2006, 12:10
Default multiple body problems (really trivial)
Skander
Hello all, I am just learning Fluent and have a simple question. I need to model a baseball travelling through air. The ball is both translating and rotating within a volume of air (think curve ball in a baseball game). I would like to model the ball as one solid, and the volume of air around it separately- then apply a rotational boundary condition to the ball and the fluid flow from one end of the volume of fluid to the other. Does this all make sense, and if so, can anyone recommend a tutorial or article to follow? (or just straight instruction, but that's asking too much). Thanks
Skander
Old   October 24, 2006, 04:07
Default Re: multiple body problems (really trivial)
Vincent
Your approach seems OK. Use a velocity inlet and a pressure outlet, and run an incompressible simulation (I suppose the Mach number is well below 0.3).
HOW TO GIVE BODY HEAT GENERATION TERM NITUL KALITA FLUENT 3 December 18, 2008 12:23
cooling a solid body Ralf Schmidt FLUENT 1 April 16, 2007 11:54
Problems with SUPG body force term FEM question Main CFD Forum 0 January 21, 2006 18:51
Some problems with Star CD Micha Siemens 0 August 6, 2003 14:55
unstructured grid sreekanth Main CFD Forum 1 August 6, 2001 16:09
