nusselt number
Old   October 18, 2006, 15:16
Default nusselt number
meenu
hello,
i just want to that does fluent gives a localized Nu number i.e the value of nusselt number at a particular point? Thanks!!
Old   October 18, 2006, 19:17
Default Re: nusselt number
Ryan
Hi Meenu,
I presume it does. You would need to write a UDF for that.
You can plot the nusselt number to check weather your solution has reached converged state in a transient flow.
I assume you are working on boiling.
Regards Ryan
Old   October 18, 2006, 22:09
meenu
hey!! Thanks Ryan, I working on a heat transfer problem in a cylinder with an inner cavity containg water which is heated...using nusselt no i want to calculate the h(heat transfer coeff.) at the inner wall of the vessel. As far as i found it gives me nusselt no. for the water zone but my question was can it give at a defined point. I have never used UDF in fluent.
Please guide me if i need to do tht where to start from?
Thanks!!
Old   October 19, 2006, 00:12
sach
udf may not be required, tri to monitor a point surface and you can plot surface heat transfer function on tha same
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
