Help required regarding wall boundary condition
Old   October 9, 2006, 08:12
Default Help required regarding wall boundary condition
Rashad
I am simulating flow between two plates. the flow is due to vertical harmonic motion of a plate between these to plates and i am using dynamic mesh. Every thing is running fine but At the moving plate i am using no slip boundary condition. when i plot velocity at the wall of the moving plate it gives always zero velocity instead it should give velocity of the plate at that instant as plate is moving.. Can any body suggest me what i am doing wrong or i should change wall boundary condition. Thankyou for Reply RASHAD
Old   October 9, 2006, 19:31
Default Re: Help required regarding wall boundary conditio
Rajit
Hi Rashad,
By default Fluent declares all walls to be no slip and adiabatic. Hope you knw what these terms mean.
Based on your statements you need to declare a free slip condition near the wall.
Thanks Regards Rajit
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
isothermal wall boundary condition Neil Main CFD Forum 3 November 9, 2015 03:34
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 09:28
match uds boundary condition in wall & wall-shadow pour FLUENT 0 May 20, 2008 09:56
