Regarding the rotation direction
Old   October 7, 2006, 13:36
Default Regarding the rotation direction
HSeldon
Hi all, I´m working with a car and I´m stuck with a simple issue. How can I know wich is the rotation direction of the wheels? My problem is as follows: If you look the car from the side it lies on the ZY plane, the nose is pointing to the Y negative (so the air is set to flow in the positive Y direction). I put the two origins of the rotation axes in the middle of each wheel and the rotation axis direction is X=1 Y=0 Z=0. Whit this configuration, are the wheels rotating ok or are they rotating in reverse?? I hope I was clear.. sorry for my english.
Thanks in advance.
Greetings from Argentina.
Old   October 8, 2006, 23:57
Default Re: Regarding the rotation direction
Rajit
I presume your axis is pointing away from the screen.If thats the case your problem set up is right.If the X axis is pointing into the screen then it has to be -1.
Thanks Regards Rajit
Old   October 9, 2006, 04:30
sach
hi if the rotational axias is coming put as a normal from the view plane apply left hand rule, rotational speed should be +ve
let me know for any quary sachcool80@gmail.com
Direction of rotation Gab CFX 6 November 16, 2017 17:19
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
Direction of Rotation of Radial Turbine ghoshi1983 CFX 8 June 19, 2012 11:16
Axis of rotation for centrifugal compressor Mattia FLUENT 4 October 22, 2007 12:05
Relief Plots in CFX Michael CFX 15 June 30, 2006 09:01
