GAMBIT meshing problem for boundary layer
Old   October 7, 2006, 13:31
Default GAMBIT meshing problem for boundary layer
Falah
Hi, I have a problem in gambit, when I try to mesh a volume using the boundary layer. The error message is "Initialization failed perturb boundary nodes and try again"
Any suggestion? Thanks in advance.
Falah
Old   October 9, 2006, 04:32
Default Re: GAMBIT meshing problem for boundary layer
sach
show me the geometry I can give you the solution, before that check the tranverse edge of the geometry if 1) there the node spacing is very low (no of nodes more) 2) split of the domain by the nodes is difficultr
let me know for any quary sachcool80@gmail.com
Old   November 30, 2020, 15:16
physics baali
somia baali is on a distinguished road
i think the problem in , when you create boundary layer you select edge not face
in 3D you must select face not edge
somia baali is offline   Reply With Quote
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 01:35
Meshing problem in gambit abhishek mukherjee FLUENT 1 July 22, 2008 05:23
Simple Meshing Problem with Gambit Mario FLUENT 4 April 18, 2003 10:52
Gambit Meshing export to fluent minor problem John c. FLUENT 2 February 6, 2002 17:52
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
