gridgen to fluent problems
Old   October 6, 2006, 05:26
Default gridgen to fluent problems
Nico
I am exporting some mesh from gridgen to fluent in cas format. In fluent i am getting some face handedness problems when running grid check (2 LH out of 2m faces). I d like to know if there are any commands in gridgen to check that? Is grid repair really repairing the mesh correctly (i cant reload a repaired mesh).
Regards,
Nico
Old   October 7, 2006, 14:03
Default Re: gridgen to fluent problems
John Chawner
Hello Nico.
It's difficult to diagnose your mesh's specific problem from this description. Gridgen's Examine command in the Block menu can be used to check the quality of your volume mesh.
Please consider contacting Gridgen Tech Support at 888-GRIDGEN or support@pointwise.com.
Old   October 8, 2006, 11:39
nicolas
my problem is left-hand/ right hand faces.
Old   October 8, 2006, 13:28
John Chawner
Left-handed structured blocks usually result when one of the faces has a degeneracy. For example, when one of the faces is collapsed to a line (a pole). This type of topology may confuse the block assembly algorithm such that the resulting block is left-handed. Any structured block without degeneracies should automatically be right-handed when created.
However, at any time you can change the handedness of a block using the Specify I,J,K (or Specify Xi, Eta, Zeta) command in the block menu.
Fluent Convergence Problems Vidya FLUENT 24 January 1, 2016 14:01
[ICEM] Problems with export 2D mesh from ICEM to FLUENT newcomer ANSYS Meshing & Geometry 54 September 20, 2014 13:40
Gridgen to Fluent bro6789 ANSYS 1 January 2, 2010 13:16
Problems with exporting Gambit mesh to Fluent Alex Mozharov FLUENT 4 November 24, 2002 02:17
Problems with Fluent Jacek Main CFD Forum 2 August 16, 2002 05:14
