Gambit IGES import numeration issue
Old   October 4, 2006, 16:45
Default Gambit IGES import numeration issue
Nicolas Meynet
Hi
I'm working on a geometry in CATIA that I export to gambit as IGES, STEP or directly as a .CATPart. But when you modify the gemetry in CATIA ( i.e. the position of a vertex), the Gambit numeration scheme for vertex, edges and surfaces change. This make imposible to reuse the Journal to generate the new mesh.
Any solution ?
Thanks
Old   October 7, 2006, 13:44
Default Re: Gambit IGES import numeration issue
HSeldon
Hi Nicolas, I had the same problem with journals in gambit. I think they work well when you are creating geometry in gambit. Otherwise the program has no criteria to label vertex, edges, faces... in the same locations with differents igs. Perhaps if you´re dealing with the same geometry, but with more than two modifications (let´s say and airfoil with several angles of attack) you could import the geometry, modify it for the first time in gambit, save the journal, edit it for the next problem, and keep going. It should work.
I hope this helps! Greetings from Argentina.
how can i import igs file in gambit? Javier FLUENT 2 May 23, 2011 11:51
can anyone tell me how to import parasolid file in Gambit?? sandip FLUENT 1 December 4, 2009 10:24
How to make a dat file to import to Gambit Elham ANSYS Meshing & Geometry 2 November 7, 2009 01:32
iges geometry file gambit import giacomo FLUENT 0 May 14, 2007 13:32
How to import PARTRAN file to Gambit?! anisa FLUENT 4 June 7, 2005 05:24
