October 1, 2006, 04:59 |
memory problem
Hi everyone:
fluent stops the run and am receiving message below Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc pp, size 23537728, t 12, myid 1000000. what is this migth be? |
October 1, 2006, 19:24 |
Re: memory problem
Malloc = Memory Allocation function. The C language standard library functions is explained in many books on the C language. Decrease the number of cells, increase the RAM, use the LINUX/UNIX operating system (if you are using windows), if your computer file system is FAT32 reformat to NTFS,..you have many choices, select the most appropriate to your budget and Good Luck
Memory storage problem IBM-machine, xlf compiler | abelme | Hardware | 0 | April 21, 2011 09:16 |
combustion problem | mcnair | CFX | 9 | March 22, 2011 15:06 |
Fluent Parallel Memory Usage | David Christopher | FLUENT | 1 | March 3, 2011 03:20 |
RAM memory problem | alpha | Main CFD Forum | 8 | February 12, 2008 12:07 |
"Memory too low" problem with Fluent HELP NEEDED | Amr | FLUENT | 6 | May 8, 2006 13:06 |
