Fluent graphics problem
Old   September 30, 2006, 08:15
Default Fluent graphics problem
smalawi
I keep getting errors when trying to plot grids or simulation resultsin fluwnt 6.2. aprearantly some hoops driver have problems. i tried uninstalling fluent (6.2) and reinstalling it several times but the problem still remains. All other fluent functions are running fine!
I have win xp home running on my laptop PC.
the error massages vary here are and example:
Error: Floating point error: divide by zero
Error Object: ()
How to fix this?
Old   September 30, 2006, 16:52
Default Re: Fluent graphics problem
Ralf Schmidt
Hi!
For the floating point error in general, check:
http://www.cfd-online.com/Wiki/Fluen..._I_avoid_it.3F
BUT, there is nothing, that has to do with graphics, so sorry... I don't know further...
It might be, that your solution is not ok. So if you tell Fluent to plot values, that are not defined (eg. divided by 0) it might return the floating point error...
Ralf
Old   October 1, 2006, 07:36
smalawi
Thanks for the hent, but the file and solution are both correct. They are from old runs and work with other PC's.
I'm sure its the graphic driver, it actually show that at times, and the best solution as I were told is to fromat the laptop. Not the easest solution!
Old   October 1, 2006, 07:55
Ralf Schmidt
I had a problem with the grapics driver with unix. the solution was, to start fluent with that command:
fluent 3d -driver x11 &
I don't think, you can do that with xp, but there is maybe something similar.
Ralf
Old   October 2, 2006, 13:08
Allan Walsh
Are you using the default graphics driver? For Windows, the msw driver is more general and is sometimes needed. Fluent can be started in Windows with other drivers using the -driver msw (or something similar) command.
Old   October 4, 2006, 21:09
Riaan
I see this often as well.
Try the -driver msw command whne you load Fluent.
Old   October 5, 2006, 04:46
Rashad
May be this problem is due to low memory of graphic card as i solve this problem by updating my graphic card. Check it
Old   October 11, 2006, 18:45
lucero
I have the same problem, but I don`t know how to start Fluent 6.1 with "driver msw command" in WindowsNT. Could anyone tell me how to do that, please??? I'm desesperated
Old   October 17, 2006, 10:01
tuw
I have similar problem too. But i think i finally get to solve it after many times of trial and error.
I am using window XP SP2, Pentium 4 1.6GHz, 640mb RAM. Due to unsatisfied performance of my default graphic card (64mb 4x), i have change the graphic card to ATI Radeon 9550 128mb. The VGA card is great but my CPU tend to unable to cope with the changes.
When i optimized the acceleration of my graphic card fully, my fluent cant show the proper display of grid (not to mention any display of contour), problems like the "floating error" and "divided by zero" occur. But when i reduce the acceleration by 50%(or more), the display of fluent become normal.
You can try this--- reduce the acceleration of your graphic card. Hope this work.
tuw
Old   June 8, 2009, 23:14
hugo soto
materioscura is on a distinguished road
Originally Posted by tuw
;136347
tuw
Heyyyy man, I have tried your answer and I had got success with it!!!
Thanks for you help. Bye.
materioscura is offline   Reply With Quote
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 21:23
fluent convergence problem josip76 FLUENT 0 May 26, 2011 21:08
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls MikeTichondrius ANSYS Meshing & Geometry 1 February 9, 2011 14:31
Problem using parallel Fluent Gustavo FLUENT 0 June 28, 2004 00:12
Problem: graphics display in prostar main window Jiaying Xu Siemens 8 February 14, 2002 09:08
