udf begin_c_loop problems
Old   September 27, 2006, 10:41
Default udf begin_c_loop problems
Abigail
I am trying to write a udf in order to count the number of cells within a certain zone in my domain. I will then input a source in this zone the value of which will depend on the number of cells. I am doing this because I want to make sure I get the same source value in different zones that will have different number of cells (it is a tetrahedral grid.).
My main question/problems are:
1) Have I understood correctly in thinking the udf will put the source value in at each cell.
2) How does the fluent macro begin_c_loop….end_c_loop work. I was hoping to use it to loop through the cells to count the number in my zone and then use a second loop to input the source value but this does not seem to work. How can I get it to move out of the first loop?
3)I have pasted my code below. I put in a print to screen command at the end of the first loop counting cells to check what was happening. All that happens when I run this is it prints out the number of cells, and keeps adding to them and printing them out. When I compile I get several warnings saying my x[1], x[2] are used uninitialised and for the final line it gives a warning "Control reaches end of non-void function."
Thanks for any help Abigail
#include "udf.h"
DEFINE_SOURCE(my_source, cell, thread, dS, eqn) { real x[3]; /* this will hold the position vector */ real source; real i; real no_of_cells; real Source_Quantity; real small_x_value,large_x_value,small_y_value,large_y_ value,small_z_value,large_z_value; small_x_value=2.08; large_x_value=2.18; small_y_value=1.10; large_y_value=1.20; small_z_value=1.625; large_z_value=1.725;
begin_c_loop(cell,thread)
C_CENTROID(x,cell,thread);
if ((small_x_value<=x[0])&(x[0]<=large_x_value))
if ((small_y_value<=x[1])&(x[1]<=large_y_value))
if((small_z_value<=x[2])&(x[2]<=large_z_value))
/* Find number of cells source is inputted over*/
i=1;
no_of_cells=no_of_cells+i;
else
else
else
end_c_loop(cell,thread)
printf("\n Numberofcells=%f\n",no_of_cells); /*print no of cells to screen for check*/
Source_Quantity=(500/(no_of_cells)); begin_c_loop(cell,thread)
source=(Source_Quantity);
dS[eqn]=0;
else
source=0;
dS[eqn]=0;
else
source=0;
dS[eqn]=0;
else
source=0;
dS[eqn]=0;
} return source;
end_c_loop(cell,thread) }
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 07:43
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
problems with UDF to set contact angle poiuy219 Main CFD Forum 0 April 30, 2009 11:43
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
