Mixture model with one compressible fluid phase
Old   September 26, 2006, 10:11
Default Mixture model with one compressible fluid phase
oden
I try to inject a compressible gas into a vessel filled with a hot liquid at high density. The inlet conditions of the gas are pressure = 4.5 bar, temperature = 229 K and density = 9 kg/m3. The inlet Mach number is about 0.95. The gas expands (jetting) and forms a bubble column, the bubbles finally rise and induce the motion of the liquid phase.
It was suggested by FLUENT to use the mixture model (gas: primary phase and ideal-gas law; liquid: secondary phase). Other settings are SKE model, Standard wall functions, initially low relaxation factors (pressure, momentum and volume fraction 0.2 - 0.3)and first-order upwind discretisation. The time step size is 10-5, but in any case, the solution does not converge. Smaller time step sizes show the same behaviour.
Has anybody experience with similar flow conditions?
Thank´s a lot for your response,
Juergen
Mixture model priyanka.asp FLUENT 5 April 16, 2020 03:18
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Two phase model? pathway FLUENT 0 September 16, 2009 00:41
MULTIPHASE - FREE SURFACE & MIXTURE MODEL Aris FLUENT 3 April 28, 2009 12:46
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 02:40
