finding pressure gradient?
Old   September 13, 2006, 19:56
Default finding pressure gradient?
lauren
Hi all,
I've got a steady-state solution for a very basic flow problem and am trying to get Fluent to tell me the pressure gradient at places like the outlet or a surface, for example. I see dp/dx listed in both the "Plot" and "Report" menus, but for some reason it always just plots or reports zero. Any ideas what I'm doing wrong? (Or maybe that's not even the right thing to be trying??)
Many thanks, Lauren
Old   September 21, 2006, 22:23
Default Re: finding pressure gradient?
zxaar
try plotting it for the surface inside the domain, you might be trying to see gradient at the face of outlet or at outer surface for which fluent has zero values. solver does not calculate gradients for these surfaces, and interpolate the values from gradeints inside if the values at surface are needed.
Inputting pressure gradient in Fluent Josyula FLUENT 2 December 23, 2009 08:26
Atmospheric pressure gradient Luc3er FLUENT 1 October 30, 2009 07:46
Pressure gradient in particle simulation Mikka Main CFD Forum 0 June 30, 2007 23:16
Hydrostatic pressure gradient Craig Finch (Finch) OpenFOAM Running, Solving & CFD 10 March 1, 2007 00:02
Flat plate with pressure gradient Sheila Main CFD Forum 3 September 24, 2005 14:58
