problem with very simple ufd
Old   September 13, 2006, 06:28
Default problem with very simple ufd
Ralf Schmidt
Hi!
I have a problem with a very simple udf. I have a cuboid volume, and i want about a quater of it to have a very high viscous resistant.
I wrote a simple udf that defines the resistant, but it dosn't work... the flow through the cuboid is straight where it should be rederacted by the high resistance zone.
That is my udf:
#include "udf.h"
DEFINE_PROFILE(vis_res,t,i)
real x[ND_ND];
real a;
cell_t c;
begin_c_loop(c,t)
C_CENTROID(x,c,t);
if( x[0] < -150)
if( x[1] < 1200)
if( x[2] < -250){
a = 10000000000;
else
a = 0;
F_PROFILE(c,t,i) = a;
end_c_loop(c,t)
Old   September 13, 2006, 10:15
Default Re: problem with very simple ufd
cadaei
are the values of the centroid x correct? they seem very large to be in metres
Old   September 13, 2006, 10:33
Ralf Schmidt
the volume is defined in mm. The cuboid is 300(x) by 150(z) by 600(y) mm. Its center is at -150(x), -250(z), 1200 (y) mm.
So the values I define are right in the middle of the volume.
The grid is also scaled in mm.
I noticed now, that even when I change the value for "a" after the else statement, there is no change in the simulation.
What is the problem??
Ralf
Old   September 14, 2006, 17:35
Scott
The UDF documentation clearly states that all units in UDFs must be in SI, so length is in metres.
Old   September 15, 2006, 11:38
Default Thats it!
Ralf Schmidt
Hi!
Thanks for that! I think, thats it! The simulation shows more or less the results, i expected, but it is very slow...
Thanks anyway...
Ralf
Very simple natural convection problem Naseem FLUENT 19 December 17, 2020 17:00
1D thermal stress problem simple barrodbeam newsboost OpenFOAM Running, Solving & CFD 3 January 2, 2009 16:12
Simple Meshing Problem with Gambit Mario FLUENT 4 April 18, 2003 10:52
SIMPLE code for 3_D problem bobby Main CFD Forum 1 December 26, 2000 00:20
? Simple CFD problem Davy Main CFD Forum 0 August 21, 1998 07:19
