Polyflow memory error
Old   September 13, 2006, 04:20
Default Polyflow memory error
markus
Hello everyone,
I am getting the following error just at the beginning of my Polyflow simulation:
Buffering on Disk in C:\DOKUME~1\Markus\LOKALE~1\Temp Alternate path: $TMPDIR (unix) or %TMP% (Windows) Global Memory Information :
Swap space : 343.9 Mbytes
Disk space : 861.9 Mbytes
RAM : 83.4 Mbytes Elimination cost : 328717.7 MFlop
Error in SLVMEM
Not enough memory (in core / out of core)
Only 0.0 of the 77.5 MB for the Schur complements
have been allocated
All memory for work vectors has been allocated
Only 41.7 of the 83.4 MB for active matrices
have been allocated
I have a Windows XP Pro 32bit Machine with SP2, 2 CPUs (option -opt 128) and 4GB RAM. The 2-dimensional mesh contains only ca. 7000 nodes and the problem is viscoelastic. When using the same dat file and geometry but with a coarser mesh of only ca. 4000 nodes the sim runs fine, and does not even buffer on disk.
Does someone know about this problem? And does perhaps someone know of an article that deals with polyflows swap mechanism?
regards, Markus
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 07:12
user defined function cfduser CFX 0 April 29, 2006 11:58
