Rotating Propeller
Old   September 6, 2006, 11:21
Default Rotating Propeller
Nolin
Hello, I am somewhat new to fluent. I plan on using Gridgen to make the mesh for my project. I'm trying to figure out how to have a rotating object in the solver. I've been searching the forums and I keep seeing things like rotating reference frame and relative velocity. I can't seem to find anywhere that explains how to make a rotating object. My project is similar to a ducted fan engine although it's very unrelated. So how do I make it so that I can have a static shroud with a rotating propeller inside it? Any info would be appreciated. Thank you.
Old   September 7, 2006, 00:07
Default Re: Rotating Propeller
Nolin
Ok, so I figured out how to set the moving wall properties, but do I need to do anything to the stuff around it (i.e. the other walls in the area, the block that it's a part of)?
Rotating propeller in a finite freestream velocity asma CFX 9 January 7, 2014 07:14
rotating propeller in stationary baffled vessel wlt_1985 FLUENT 27 March 30, 2011 02:22
rotating propeller in OpenFOAM 1.6 jiejie OpenFOAM 10 January 7, 2011 02:08
Counter rotating propeller (propfan) Ball FLUENT 0 August 13, 2008 17:14
propeller rotating at zero inflow velocity Ammu FLUENT 1 July 23, 2005 14:36
