connecting Faces with different mesh intervalls |
August 30, 2006, 06:08 |
Hi
I'm trying to mesh a simple tube with a direction change at the end. For this reason the room where the air is redirected is outfitted with a finer mesh than in the other parts of the tube. Now the problem: Cause of an UDF I want to jump from a mesh intervall of 5 to 1 at one face. the problem is that when I try to connect the faces one of the meshes is deleted and is it not possible to generat the favoured mesh intrval. It is now possible to generat an interface and import the mesh into fluent and connect it by the programm but due to a high amount of these interfaces I 'm looking for an easier way to sortout the problem . Thanks for any help |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
Mesh faces | m.maneshi | Fidelity CFD | 0 | October 18, 2010 07:06 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
