Is "operating density" sensitive to the resluts?
Old   August 29, 2006, 12:02
Default Is "operating density" sensitive to the resluts?
Joe
Here is my understanding of Operating Density in Fluent:
Use Tref= initial flow temp, then calculate Density_ref based on p/density = RT. However, because of combustion at the bottom of the domain, the flow temp changed very quickly and highly non-uniform. Anybody had the problem with the operation density? If the pressure outlets at low level and high level have quite different temp, will the results be sensitive to the operating density?
Thanks.
Joe
operating pressure and operating density phil FLUENT 5 November 7, 2017 18:02
buyoancy and operating density Zeh FLUENT 2 March 24, 2007 08:22
operating density in buoyancy driven flow Marie-Anne Main CFD Forum 2 March 24, 2006 10:52
Specified Operating Density for Compressible VOF Andrew Wick FLUENT 1 November 14, 2005 05:58
Warning 097- AB Siemens 6 November 15, 2004 05:41
