Need help setting a boundary condition...
Old   August 28, 2006, 05:34
Default Need help setting a boundary condition...
HSeldon
Hi, I have two quick questions: 1) Supposse that I´m working with a jet engine airplane, what boundary condition should I put for the engine air intake? 2) In the case of a car, wich boundary condition should I set for the air intake in front of the car (don´t know the name for that in english)?
Thank you!
Old   August 28, 2006, 06:56
Default Re: Need help setting a boundary condition...
Kyril
It depends what you know. Do you know a mass rat per second? a velocity? a pressure?
Velocity inlet, mass flow inlet or pressure inlet should be good.
For an airplane, you can use pressure far field (only if you've meshed far enough before your inlet).
Hope that helps !
Old   August 28, 2006, 15:10
HSeldon
Perhaps I didn´t say something important, I want to work with the whole plane (including the press far field and also the engine), so basically I have to set two boundary conditions, my question is, how I have to set the engine intake to have a real flow behaivor around the plane.
Thanks!
Setting the inlet boundary condition with inclination saisanthoshm88 CFX 1 October 4, 2011 07:41
Setting boundary condition for C-grid airfoil quarkz FLUENT 0 December 28, 2010 15:37
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 12:32
CFX Solver : Sudden crash Hervé CFX 2 June 16, 2008 07:40
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
