How to determine an order of cells?
Old   August 26, 2006, 23:26
Default How to determine an order of cells?
braket
Hi, everybody,
I draw a square in Gambit and copy it to get an another surfce parallel to the original square, then mesh them. In Fluent, using "cell_t c" in a UDF, I got sort orders of cells in two squres. I found the sort order of cells in the original squres is from bottom to top, but in the its paraller surface the order is from top to bottom. In the other word, the cell numbered "1" in original surface lies in its left-top corner, however the cell numbered "1" in the paraller surface is in its left-bottom corner. My question are (1)why are their sort orders different? (2) how does the FLUENT determine the sort order of mesh cells in a surface or a volume?
Thank you very much! braket
Old   August 27, 2006, 16:25
Default BTW, how to determine which is the first cell in a
braket
By the way, how to determine which is the first cell in a thread? In a squre, there are four corners. which corner a cell lies is the first cells in the squre thread? thank you very much! braket
Old   August 28, 2006, 03:54
Default Re: BTW, how to determine which is the first cell
RoM
I dont know a way to determin the cell order in a grid. Cells are stored in a sprase matrix and to reduce memory consumption some cells are shifted to positions where usually zero elements are stored. You can even force this with grid->reorder. Here is a small expamle to illustrade the process:
Original 5x5 matrix (A-E are stored elements)
A0000
0B000
00C00
000D0
0000E
3x3 matrix after reordering
BA0
0C0
0ED
As you can see the new cell oder is screwed up and there is no shure fire way to determin the cell order for large grids.
RoM
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Second order upwind is not UPwind!!! Far CFX 9 May 31, 2011 09:21
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 02:50
find degenerated cells Pete Siemens 3 April 22, 2005 06:49
SOS! HELP! max number of cells :( Jas Phoenics 4 February 14, 2004 11:12
