turbulence model
Old   August 25, 2006, 13:06
Default turbulence model
greg
hi.
can you (in few words) explain me how to use viscous models. I mean which model is proper for which problem (if it is possible to descibe in few words). I know that some of them are more time and CPU consumption. Which are the best for use with problems involving mass and heat transfer.
thank you for help
Old   August 26, 2006, 06:25
Default Re: turbulence model
saeed
u should describe ur problem with more detailes ... what's ur geometry of ur problem .. do u use heated walls?
Old   August 26, 2006, 08:04
gladiator
1-if you have a rotational flow you must use k-omega. 2-if you have a simple flow (with a few rotation or without) :k-epsilon,rng...... 3-if you want to have the precistion you must use :rsm
in conclusion ,you must use the model of turbulence for two condition: 1-good results.
2-optimal(few cpu). best regards
Old   August 26, 2006, 12:07
greg
to saeed: I have solar radiation, mass and heat transfer, no moving parts (no rotating parts), just flow in rectangular chanel (pipe). Velocities of fluid from 0.001 m/s to 0.5 m/s. No chemical reactions
to gladiatior: thanks. This short quide is very, very, very good and useful. Meybe you know a website or have any pfd with such (simple language,good description ) tutorials of turbulence
thanky you both of you guys
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
Fan heater model: what turbulence source to use? andy20 CFX 7 March 3, 2008 17:42
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 17:15
