August 25, 2006, 05:53 |
low-re-kw-model
hi all, can anybody help me regarding low-reynolds number kw model. is it available in fluent. if it inbuilt in fluent how can i get this. thanks with regards
August 25, 2006, 09:51 |
Re: low-re-kw-model
hy! enable the ke-standard model and then try to tape in the fluent interface
define/models/viscous/turbulence-expert clem |
August 25, 2006, 10:17 |
Re: low-re-kw-model
I think that if you check the "transitional flows" in the K-omega menu, then it works as a low-Re model, and uses the enhanced wall treatment. For more info check chapter 10(turbulence modeling) in the fluent user's guide
August 25, 2006, 11:22 |
Re: low-re-kw-model
thanks Antonis, i will check. thanks once again
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 14:57 |
Turbulence Model for low Reynolds Number | Muhammad Shakaib | Main CFD Forum | 2 | July 3, 2006 16:42 |
UPWIND-BIASED and Low Re K-Epsilon Model | Valdemir G. Ferreira | Main CFD Forum | 5 | June 20, 2000 00:13 |
