Vapour formation with heat and mass transfer
Old   August 21, 2006, 01:43
Default Vapour formation with heat and mass transfer
Rajit
Hi all,
Has one simulated the formation of vapour in a forced convection process using a UDF.
Iam not reall sure how to intiate the vapour formation based on temperature using the eulerian model.
Any help in this regard is much appreciated.
Thanks
Regards
Rajit
Old   August 21, 2006, 06:54
Default Re: Vapour formation with heat and mass transfer
greg
I`m trying to do it but I`m using VOF model. There is few udf`s in UDF manual like define_mass_transfer or define_source. You can check it. You need to check if you can use it in Eulerian model (I don`t rememer). Both of this udf`s based on saturation temperature. Check hfilm and boil tutorials. I`m not sure if they are appropiate for forced convection. good luck
Old   August 21, 2006, 19:46
Rajit
Hi greg,
Thank you very much for your reply.
Where can i find the boil tutorial.wil be great if you can let me know.
Thanks once again.
Regards Rajit
Old   August 22, 2006, 06:49
greg
on www.fluentusers.com
regards
greg
in case you you will not be able to find it I can sent it to you
Old   August 22, 2006, 22:45
Rajit
Thanks a million Greg.
I have found it.
Thanks
Regards
Rajit
Old   August 24, 2006, 06:34
greg
good luck
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
