rectangular elbow air duct problem
Old   August 20, 2006, 18:29
Default rectangular elbow air duct problem
tony
I am trying to simulate a rectangular elbow which filled with acoustic glass fiber by 3D models, but the pressure drop i got is about 50% of tested data. Your help is appreciated. Rectangular elbow inlet and outlet 25" width, inner wall R11", outer wall R37", upstream and downstream ducts 40" width, elbow and ducts 24" thick. I tried standard k-e, realizable k-e, RNG k-e, RSM models, Y+=110~200, standard wall function. The pressure drops I got by these models are quite close but far away to tested data. Your comments are highly appreciated.
Tony
Old   August 20, 2006, 18:53
Default Re: rectangular elbow air duct problem
Ahmed
how did you model the glass fiber zone?
Old   August 20, 2006, 20:07
Tony
I do nothing to Fiber zone.The fiber is covered by two perforated sheet metal plates and I just want the pressure drop at air side. Howerver, the perforated walls are pretty rough, I give a roughness and just a few percent of pressure drop increased. I am not comfortable with the ROUGHNESS of the covers, they have 1/8" dia. holes @ 3/16" centers. I don't know it's good enough to assume a roughness for them, I hope it's not the reason why the result is off. Because I simulated a rectangular straight silencer, the pressure drop looks good. I am wondering if the flows are too BAD to be simulated? Thanks
Flow is not converging in natural convection problem of boussinesq model for air rahulsharma FLUENT 4 December 2, 2020 22:07
supersonic flow in a rectangular duct charndrabose_mit CFX 0 July 28, 2011 12:25
2D simulation of circular and rectangular duct mvee FLUENT 4 March 24, 2007 00:40
Turbulence Model for Rectangular Duct Flow ken FLUENT 4 May 26, 2005 21:39
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 10:22
