Parallel Fluent: trouble going from 2 to 4 CPUs
Old   August 17, 2006, 16:31
Default Parallel Fluent: trouble going from 2 to 4 CPUs
Mario
I started programming my CFD simulations in parallel to use with a Linux Cluster. I can run Serial simulations just fine, and I can run Parallel 2 CPU simulations fine as well. When I try to increase the number of CPUs higher than 2, the simulation halts when the iterations begin.
At first I thought it might be some of the parallel coding that I added, but I went back to the original serial version and I get the exact same result. It makes no difference if I spawn 4 nodes on 1 dual processor machine or spawn 1 node per CPU on 2 different dual processor machines (thought it might have been a communication issue).
Is there anything obvious that I should be looking for to fix in my UDF file? I am launching Fluent by:
fluent 2d -g -t4 -alnamd64
The -alnamd64 switch is needed for that particular cluster. I tried the switch -psmpi as well, but that didn't help.
Any suggestions?
Old   August 17, 2006, 16:52
Default Re: Parallel Fluent: trouble going from 2 to 4 CPU
cadaei
try -pnmpi. you will need to use -cnf=hostname file path with the -pnmpi switch. hostname file is just text file with host names eg. node1 node2 etc
Old   August 17, 2006, 17:54
s.feven
try partitioning the grid in serial before running in parallel
Old   August 18, 2006, 16:56
Mario
Thanks for the responses. I tried the -pnmpi switch and I also tried partitioning the grid in serial before running in parallel, but neither seemed to help
Is there anything else (that I may have written in my UDF) obvious which would cause the solver to get stuck? I thought about File I/O, but I disabled any file read/write and that didn't help.
The UDF basically records velocities from particular cells (C_U,V,W), computes an output, and applies that value as a boundary input (F_PROFILE). I suppose I could try (as a test) getting rid of the UDF completely and see if Fluent still gets stuck....
Any more suggestions?
Old   August 21, 2006, 05:21
mAx
hi try to spawn manually your nodes, and don't type -t4 option. It should be done before reading your case
Old   August 23, 2006, 11:01
Mario
How do I manually spawn nodes from Fluent without the GUI? I've read Ch. 30 (Parallel Processing) of the Fluent Manual, but it only mentions spawning nodes through the GUI.
I created a test simulation which did not use any UDFs and I get the exact same results when going from 2 to 4 CPU's (simulation "locks up" upon beginning iterations - as if it is waiting for something....), so at least that narrows down the possibilities.
It is most likely a communication issue on the cluster itself, but I'm not sure how to get around it.....
Old   August 24, 2006, 01:17
mAx
try with gui. you will know immediatly if your cluster is well set up. If it's ok, then write a journal while spawning your nodes. After that you will be able to spwan your nodes "manually" and automatically. It's like a -cnf options with hostfile
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 10:32
Fluent Parallel Error Will Humber FLUENT 2 April 3, 2008 15:15
Fluent parallel poovanna FLUENT 0 March 24, 2007 00:22
running multiple Fluent parallel jobs Michael Bo Hansen FLUENT 8 June 7, 2006 09:52
error parallel fluent session Diet FLUENT 2 January 27, 2005 13:31
