weired behavior in discrete phase
Old   August 15, 2006, 12:00
Default weired behavior in discrete phase
Arash Kashani
does anyone really know how discrete phase model works in fluent?
I use discrete phase model in fluent to inject a single droplet and study its breakup, nevertheless I get differenr results for child drop sizes every time I run the same case, total mass of liquid particles are conserved though. Has anybody ever experienced the same thing? I wonder if I have made any mistakes or if this is in the nature of discrete phase modeling.
Old   August 30, 2006, 08:30
Default Re: weired behavior in discrete phase
kirankumar
yes i also faced similar problem, descrete phase calculation is based on your conuous phase solution.so it is naturally varie with iteration and with run also . but in many cases it is negligible if you take more particles. but in your case you are taking only one particle. hoping for your feed back kiran
Old   August 30, 2006, 17:12
Arash Kashani
well, I found the answer in the KIVA II manual. Fluent basically ,like Kiva, calculates the Sauter mean diameter D32, and then determines drop sizes randomly from a x-square distribution function. that's why we get different drop sizes per run,nevertheless it seems to be reasonable if large number of drops are injected.
Discrete Phase Model vittal FLUENT 4 October 28, 2014 11:07
continuous and discrete phase coupling in fluids-HELP atmcfd Main CFD Forum 1 December 31, 2009 00:02
Discrete phase modellision through a free surface thomas Main CFD Forum 0 December 10, 2003 09:05
uncoupled discrete phase calculations AMV FLUENT 0 December 3, 2003 08:21
Discrete Phase Modeling Fred Kang FLUENT 3 October 18, 2000 11:23
