rotating disk
Old   August 15, 2006, 05:20
Default rotating disk
David
Hello, I'm simulating a rotating disk in the air but my simulation doesn't correspond to the experimental measurements. I've already meshed the disk and the control volume, and the mesh quality is about 0.3 and there aren't bad cells. Within this velocity, the temperature around the disk is about 100°C by experiment but during my simulation the temperature is only at 50°C. The aim of this simulation is to determine the moment at the axis. Now, I try to change the fluid (air) into ideal gas and change the options for the density and viscosity.
Could someone give me some advice about really important parameter ? What is really the consequence of the turbulent viscosity option in fluent?
Disk specification: Radius 95 mm; thickness 2 mm; roughness 5 micrometer, frequency 0-500 Hz
Model: k-epsilon RNG; coupled; energy
Best regards
David
Old   August 15, 2006, 10:02
Default Re: rotating disk
Peter Egolf
bonjour,
je répondrai bien volontiers à votre annonce mais malheureusement je ne parle que français ou allemand?
Old   August 15, 2006, 10:15
wolf sanders
your are very bad with fluent..... try to change job !
Old   August 15, 2006, 10:40
David
ok, i'm looking for an another job.
Old   August 16, 2006, 07:05
denovo patrick
I think that fluent is a powerful soft.... damage that it's difficult to use it. there are some people very good and some also very bad . Dammage for you !
you can go to bed.
Old   August 16, 2006, 07:07
david
help help help me please !
do not play with me.....
i am Calimero
rotating disk symmetric grid, help please bene FLUENT 0 November 5, 2010 08:09
vof rotating disk 2d bene FLUENT 1 October 24, 2010 14:18
Rotating Disk MohsenZendehbad FLUENT 2 July 13, 2008 14:43
Numerical solution to the rotating disk problem? johny Main CFD Forum 7 September 5, 2005 06:53
liquid on a rotating disk? Cehuang FLUENT 0 March 10, 2001 07:23
