August 12, 2006, 20:01 |
fluent 32 bit maximum RAM
Hi! In fluent 6.3, converting grid to poliedra, an error occurs related to RAM memory. My question is if I have 3 GB RAM plus 3 GB of Swap, the fluent can reach the 6 MB TAM or only 4?? Because of 32 bit??!!
Thanks |
August 15, 2006, 12:09 |
Re: fluent 32 bit maximum RAM
Depends on the OS. Windows will not allocate more than 2MB memory to any single process. Linux should not have this problem.
August 19, 2006, 09:45 |
32 bit win systems normally 4096 mb, but the ide banks also
use 300- 400mb ,depends how much they are but, regarding pocess you only get around 1,7 Gb with / 3GB in boot.ini, you can increase one process to max 3 GB. Adding 34-bit /PAE in boot.ini works only on 2003, as far as i know Seems you are linux, seems also your RAM is too small, sure converting the whole domain cells fluent takes some place |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
fluent 12.1 64 bit | wlt_1985 | FLUENT | 0 | April 18, 2011 12:14 |
FLUENT versions ... | Gautam | FLUENT | 3 | November 1, 2007 10:49 |
32 bit vs 64 bit FLUENT | Woo Meng Wai | FLUENT | 9 | October 17, 2007 17:46 |
maximum memory 32bit fluent version | korni | FLUENT | 6 | May 19, 2005 20:21 |
