Set_material_property: null user defined function
Old   August 10, 2006, 03:42
Default Set_material_property: null user defined function
Albert Franco
Hello all,
I'm working in a case that needs an udf to control the evaporation of species. I compile the udf and all seems to work well but when I try to set the materials propierties for the mixture and imposing a density from the udf, the following error message appears: Set_material_property: null user defined function name
I would be grateful if anybody could help me to solve this problem.
Thanks in advance
Albert
Old   April 4, 2016, 09:12
Abhay Rana
abhay.uiet is on a distinguished road
did u figure it out?
abhay.uiet is offline   Reply With Quote
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
User defined function - CO level hari FLUENT 0 October 24, 2007 01:11
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
User defined function for density gradient ben akih CFX 3 October 10, 2006 22:47
