Unsteady Result Analysis
Old   August 7, 2006, 17:40
Default Unsteady Result Analysis
HAR
I searched on the forum about how to see and analyse the results in a unsteady flow but I did not see anything. So, I would like somebody to help me with this question.
I simulated an unsteady flow and I saved the animation; so I am able to visualize the flow at any time. However, when I want to plot some results I just have the data of last simulation and I cannot plot or display the results at any time.
Could somebody tell me how to display the contours or plot the data of an unsteady flow at any time of the simulation (not only the last result that FLUENT has)?
Thanks a lot!
HAR
Old   August 8, 2006, 05:47
Default Re: Unsteady Result Analysis
erdem
hi HAR
you should save your data at at time step interval. for doing this use File->write->autosave menu in this menu the number at auto save data frequency means the time step interval that your data file to be saved. example 50 means that the data file will be saved at 50time interval. lower the value higher the disk space used
erdem
Old   August 9, 2006, 11:04
HAR
Thanks a lot for the hint!
Modelling the cross aisle direction of a steel selective rack for model analysis m8rix ANSYS 0 September 20, 2011 11:28
LES post analysis faisal_durr Main CFD Forum 0 July 13, 2011 06:52
unsteady results lid driven cavity problem student Main CFD Forum 1 July 20, 2008 14:50
naca unsteady analysis calogero FLUENT 3 March 20, 2003 18:03
Unsteady State analysis of 2 bluff objects Desmond Hui FLUENT 8 September 1, 2000 09:56
