solution diverges
Old   August 6, 2006, 23:39
Default solution diverges
mech
I am simulating micro parallel plate channel flow. It is 2D. The length is 3000 and height is 1.2 micron. I need to use slip flow on the wall which is proportional to du/dy. y is normal coordinate to the flow direction. u is the gas velocity in the flow direction. When I use 12 mesh in the y direction then the simulation converges and give the required result. But if I increase mesh number say 20 then the solution diverges. Can anybody say How can I control the solution so that it will converge even if I increase mesh number. Mech
Old   August 7, 2006, 07:47
Default Re: solution diverges
Brian
If you're not already doing so, start with the converged solution from your coarse mesh and interpolate the flow field onto your fine mesh. Starting from an already converged solution from an old mesh is much more likely to converge.
Old   August 7, 2006, 08:02
mech
Hi Brian Thank you for your prompt response. I can get converged solution from coarse but from that solutiion how I will interpolate to fine mesh I do not know. Would you describe the procedue? Mech
interFoam solution tolerances mgdenno OpenFOAM 4 September 13, 2011 13:58
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 08:51
Transient, initial variables from a previous solution nakor FloEFD, FloWorks & FloTHERM 0 April 22, 2011 05:34
solution diverges varun Siemens 1 January 11, 2005 04:10
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 14:37
