reverse flow
Old   July 28, 2006, 05:15
Default reverse flow
kam
Hey,
I am modeling fire in a single room by volumetric energy and mass sources. The room has a door. I extended the domain outside the room so I can compute better flow through the door. I set the boundary of the extended domain as pressure outlet. I am having reverse flow on this boundary which I think is causing convergence problem for me. So is that the nature of the flow or numerical error resulting from illness in settings?
Thank you, kam
Old   July 31, 2006, 08:57
Default Re: reverse flow
Miguel
Hi Kam,
I would consider two main factors, the gas expation due to the heat and the fact that O2 occupies less volume when binden to a carbon dioxide. Just then you could have reverse flow.
Miguel
Old   July 31, 2006, 10:14
kam
Thanks miguel, For the first factor Ive tried with both constant and temperature dependant propeties and I had reverse flow with both. Considering the second one I dont now if Ive got you well but if you mean O2 is entrained into the domain so you want to say it is the nature of the case. Well I dont really know and I will still appreciate any conribution.
kam
Reverse Flow Bharati FLUENT 0 September 14, 2010 02:09
Flow simulation in reverse drum mixer Patel Chirag CFX 0 July 19, 2010 16:05
reverse flow alikami FLUENT 1 June 2, 2010 05:19
Reverse flow in the VOF model yan FLUENT 1 May 26, 2005 10:14
reverse flow Giovanni FLUENT 11 October 15, 2001 04:01
