Initialization Problem...Please Help!!!
Old   July 27, 2006, 12:12
Default Initialization Problem...Please Help!!!
Ryan
Hey all, I'm trying to model diffusion throught two zones with different properties. One problem Im having is initializing the concentrations differently for the different zones. I dont understand how the DEFINE_INIT macro works. How do I set up the loops over zones and cells to isolate each species?? Is this how the main logic of this macro works? PLEEASE HELP!!! Cheers
Old   July 27, 2006, 14:23
Default Re: Initialization Problem...Please Help!!!
cadaei
have you tried using solve->initilise->patch
Old   July 28, 2006, 11:22
Ryan
I think that will work. Thanks for the advice!
Old   July 28, 2006, 12:17
Ryan
OK I have gotten to the patch part, but now Fluent won't allow me to define the concentrations differently for my 2 zones. Once I "patch" a value in one zone, it automatically does it for the other zone. Do you know how to fix this? Cheers
Old   July 28, 2006, 20:13
cadaei
I'm not sure how its patching zones that you are not selecting. Try initilising the two concentrations to zero over the whole domain and then patch them to values in zones.
you can also setup user defined patching zones called registers using the adapt->region panel
initialization problem in fluent morteza08 Main CFD Forum 0 January 17, 2011 13:04
Initialization problem when using Axisymmetry BC Eduardo FLUENT 0 August 4, 2008 10:23
coal combustion initialization problem Chetan Prahsant CFX 1 May 1, 2007 06:41
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
