July 27, 2006, 09:34 |
Oscillating Residuals
Hi all
I'm calculating a flow arround a Turbofans nacelle with mixing of core and bypass massflow using a 6 million nodes large grid. I have a converged solution for a freestream velocity of 50m/s and I now want to simulate the flow at different freestream velocities. Unfortunately the residuals for the velocities, energie and continuity are beginning to oscillate after 100 Iterations in between 1e-1 and 2e-1 with an amplitude of around 1e-1 and no convergence is reached. My Simulation parameters are: Solver: Coupled explicit parallel on 8 cpus Gas: Ideal Gas Law for Compressible Flows Turbulence: Realizable k-eps CFL: 0.2 Maybe a multigrid can solve the problem??? Thanks for any suggestions. Cairol |
July 27, 2006, 09:35 |
Re: Oscillating Residuals
ups ...
July 27, 2006, 11:13 |
What about changing the underelaxation parametres for velocity , If I were you I would decrease underrelax parametre 0.1 point and then see what happens
July 31, 2006, 05:14 |
Thanks for your Answers
I changed the under-relaxation parameter as well as the CFL-Number to 0.1 and used the coupled implicit solver instead of the explicit like Razvan suggested. Unfortunately, the same oscillation appears after a 100 iterations. Again, my simulation parameters are: Solver: Coupled implicit parallel on 8 cpus Gas: Ideal Gas Law for Compressible Flows Turbulence: Realizable k-eps - first order upwind CFL: 0.1 Massflows on inlets and outlets are more or less steady during the run, that is no oscillation appears in Massflow! Cheers Cairol |
July 31, 2006, 10:34 |
I took the segregated solver and .................................................. .................................................. ............... it is going to converge
Cheers Cairol |
Reason for oscillating residuals | fayaazhussain | Main CFD Forum | 3 | August 21, 2014 11:31 |
oscillating pressure residuals buoyant plume | mabinty | OpenFOAM Running, Solving & CFD | 0 | August 31, 2009 06:31 |
Oscillating Residuals | Cairol | FLUENT | 1 | July 28, 2006 02:47 |
Oscillating Residuals in Finer Mesh Case | Jake | FLUENT | 3 | June 16, 2005 10:34 |
oscillating residuals | dave | FLUENT | 2 | December 10, 2004 04:01 |
