Oscillating Residuals
Old   July 27, 2006, 05:50
Default Oscillating Residuals
Cairol
Hi all
I'm calculating a flow arround a Turbofans nacelle with mixing of core and bypass massflow using a 6 million nodes large grid. I have a converged solution for a freestream velocity of 50m/s and I now want to simulate the flow at different freestream velocities. Unfortunately the residuals for the velocities, energie and continuity are beginning to oscillate after 100 Iterations in between 1e-1 and 2e-1 with an amplitude of around 1e-1 and no convergence is reached.
My Simulation parameters are: Solver: Coupled explicit parallel on 8 cpus Gas: Ideal Gas Law for Compressible Flows Turbulence: Realizable k-eps CFL: 0.2
Maybe a multigrid can solve the problem??? Thanks for any suggestions.
Cairol
Old   July 28, 2006, 02:47
Default Re: Oscillating Residuals
Razvan
Better try segregated solver. The velocity is low enough and it will converge much quicker. That, of course, if you cannot use coupled implicit solver due to memory limitations.
Razvan
Reason for oscillating residuals fayaazhussain Main CFD Forum 3 August 21, 2014 11:31
oscillating pressure residuals buoyant plume mabinty OpenFOAM Running, Solving & CFD 0 August 31, 2009 06:31
Oscillating Residuals Cairol FLUENT 4 July 31, 2006 10:34
Oscillating Residuals in Finer Mesh Case Jake FLUENT 3 June 16, 2005 10:34
oscillating residuals dave FLUENT 2 December 10, 2004 04:01
