July 27, 2006, 00:41 |
Unwanted Wall Boundaries for 3D geometries
When I create a 3D geometry in Gambit and then display the grid Fluent, a wall boundary usually appears that I did not create in Gambit. It will often be named "wall" and it consists of interior faces. I cannot figure out how to delete these walls in Fluent or how to change them to a boundary type that does not impede flow.
July 27, 2006, 01:39 |
Re: Unwanted Wall Boundaries for 3D geometries
Sounds like a mistake made in gambit. You should have a look if the two volumes where the wall appears are conected to each other. hope that helps.
help with wall functions | Nick Georgiadis | Main CFD Forum | 10 | January 17, 2017 10:03 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
How i can create a wall with out boundaries??? | STK | FLUENT | 1 | July 7, 2004 13:20 |
Wall function in adverse pressure gradients | stephane baralon | Main CFD Forum | 11 | September 2, 1999 04:05 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
