Boundary condition
Old   July 19, 2006, 14:25
Default Boundary condition
tomik
Dear All, I have a question? Which boundary conditon ( wall, pressure inlet, pressure outlet, mass flow rate etc.) I must to set on boundary in order to obtain atmosferic pressure on the boundary domain??? Thanks for help, Best regards, Tomik
Old   July 19, 2006, 15:58
Default Re: Boundary condition
cip
outflow
Old   July 19, 2006, 16:44
Jason
I have to disagree there. Outflow assigns zero diffusion flux to all the flow variables at the BC, which is similar to saying the flow is fully developed. It's not universally applicable (which many people seem to forget here) and does not work with compressible flow or pressure inlets (See the fluent manual... chapter 7.10 on Outflow BCs).
If you're trying to get a constant total pressure, then use a pressure inlet. If you're trying to get a constant static pressure, use a pressure outlet. If there is forward motion of the flow, then you have to let Fluent know that, so a Pressure Inlet, Velocity Inlet or Pressure-Far-Field BC would work (VI ONLY WORKS FOR INCOMPRESSIBLE FLOW AND PFF ONLY WORKS FOR COMPRESSIBLE FLOW!!!! but PI works for both). In any of these cases, the BC should be far enough from the geometry so there's little to no iteraction between the effected flow and the BC. Otherwise you risk the BC modifying your flow field and changing the area of interest. Also, with the Pressure inlet and Pressure outlet you will probably get "reversed flow in XXX faces". This means that flow is either leaving through the pressure inlet, or entering through the pressure outlet. It's not a problem, it's just a warning becuase typically an inlet BC is used at an actual inlet where you want flow going in one direction and same with the outlet. But you're talking about using it as an atmospheric bubble, which these BCs will handle just fine. Just make sure to set the Backflow properties if using a pressure outlet.
Check out chapter 7 of the Users Guide for more information, a list of all the BCs, and information on when the BCs are not applicable.
Hope this helps, and good luck, Jason
Old   July 20, 2006, 04:25
Albert Franco
I agree, I would use presure outlet besides as Jason said outflow does not work with presure inlets.
Old   July 20, 2006, 08:03
kp
Dear Jason and other guys, I am modelling a bubble column. I want my gas to leave the top of the column where as liquid to stay inside the reactor. So what BC would you suggest in this case. Thanks. KP
Old   July 23, 2006, 23:58
Default Re: Boundary condition(Fan)
Thakorn Paiboonrotrung
Dear All, I have a question? Which boundary conditon ( wall, pressure inlet, pressure outlet, mass flow rate ,exhaust fan velocity inlet,etc.) I must to set on boundary in order to obtain atmosferic pressure on the boundary domain??? Thanks for help,
Best regards, Thakorn
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 06:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 13:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
